water block for my gpu
Solved by Wesley219,
is this right http://www.frozencpu.com/products/16422/ex-blc-1165/EK_Radeon_7870_GTX_VGA_Liquid_Cooling_Block_-_Nickel_Acetal_CSQ_EK-FC7870_-_Nickel_Acetal.html?tl=g30c309s1705#blank looking through the compatibility the PowerColor PowerColor Radeon HD 7870 GHz Edition 2GB GDDR5 (AX7870 2GBD5-M2DH) looks a lot alike to my gpu
It's hard to tell. The screw holes could not line up, or the any number of things could cause it not to work.
