Hi,
I have a MSI R9 290 gaming for which I'm trying to take the backplate off. I've unscrewed every screw that holds the pcb sandwiched between backplate and frontplate. I've taken off frontplate but now that it comes to taking off the backplate, I'm having problems.
The backplate lifts off the pcb fine except at 4 locations where the backplate is glued to pieces of something that are glued to the pcb (1 on the side and 3 on the far edge). I've tried pulling, and twisting the backplate pretty hard and I am afraid of going harder.
How do I do this? Is it supposed to be removable?
Posted Image
Posted Image
https://linustechtips.com/topic/182709-need-help-taking-off-backplate/
Probably just thermal pads. Make sure its not a screw and then pull fairly hard. I was confused as well when removing the backplate on my card. I swift tug pulled it off. Don't pull too hard as I may be wrong.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
Hi,
They're likely just pieces of adhesive. Try on one of the corners where the adhesive is to pry the backplate off. If it comes off then you'll know the rest of the pieces will.
"Rawr XD"
the backplate cannot be removed without damaging the card.
http://www.custompcreview.com/reviews/review-msi-radeon-r9-290-gaming-4g/19995/2/
If you tell a big enough lie and tell it frequently enough it will be believed.
-Adolf Hitler
Those "sticky pads" are so adhesive that I can't take the backplate off with alot of strength. I would imagine if it did come off, pcb pieces would too.
A credit card or similar will get them off, plenty of people do it when they put a water block on.
Hit it with a brick.
hehhehhehhehhehhehhehhehhehhehheh SWIGGITY SWOOTY I'M COMING FOR THAT BOOTY hehhehhehhehhehhehhehhehhehhehheh
huehuehuehuehuehuehuehuehuehuehuehue LINIXTEKTEPS R DE BES I LUV LINUX huehuehuehuehuehuehuehuehuehuehue
