So ive got a semi modular psu that i would replace with a modular one but i don't have the money right now and i want the cables to match the build as atm they are yellow :o. I was looking at these and wondering how they work
http://www.mwave.com.au/product/bitfenix-alchemy-sleeved-cable-24pin-atx-power-blackblue-ab54244
Does it go:
PSU - NON MODULAR CABLE - EXTENSIONS - COMPONENT ?
because they don't look long enough to go straight from the psu
also id want to use these cables for the CPU, 24 pin and my graphics card with has a 6 pin and a 8 pin but i cant find any 6 or 6+2 extensions so will a normal 8 pin work?
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
https://linustechtips.com/topic/182391-how-bitfenix-cables-work/
Yup! you just plug those onto your own cables. Basically you preferrably hide yours behind the mobo and let the Bitfenix ones come out. Looks very nice! Only problem is: You need enough space for your cables to be hidden entirely behind your mobo tray.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/182391-how-bitfenix-cables-work/#findComment-2450728
:o thanks that will save me money getting a modular psu even though im still tempted to get a CM v700/850 also i think i have enough room and if not ill just leave the back panel of as its against a wall anyway :P
What about the 8 pin to 6 pin on the GPU?
|| MAELSTROM ||
https://linustechtips.com/topic/182391-how-bitfenix-cables-work/#findComment-2450734
Depends what you mean by "a normal 8 pin."
You can't use a CPU 8 pin connector on a graphics card, and you can't use a 6+2 pin on a CPU.
An 8 pin graphics card connector will work for your 8 pin on your card (obviously), but I don't know if you'll be able to use an 8 pin connector in a 6 pin slot.
Look at the colours of the cables. I think the 8 pin should just have 2 more black cables (ground).
Regradless, I wouldn't personally use an 8 pin in a 6 pin slot. I don't think it will fit.
https://linustechtips.com/topic/182391-how-bitfenix-cables-work/#findComment-2450755
http://www.mwave.com.au/product/bitfenix-blue-black-45cm-eps-8pin-sleeved-power-cable-extension-ab55356
Is this for a cpu: http://www.pccasegear.com/index.php?main_page=product_info&products_id=24427&cPath=1347
and this for gpu: http://www.pccasegear.com/index.php?main_page=product_info&products_id=24421&cPath=1347
also i found a 6 pin: http://www.pccasegear.com/index.php?main_page=product_info&products_id=19234&cPath=1347
one last thing these are still extensions right? not cables that need to go straight from a psu
@mapegl
|| MAELSTROM ||
https://linustechtips.com/topic/182391-how-bitfenix-cables-work/#findComment-2450772
You're mixed up, EPS is for the cpu. VGA for the gpu.
Oh ok ill keep that in mind. need help for the colour choices though. not sure if i want black/blue or full black or full blue :P
|| MAELSTROM ||
https://linustechtips.com/topic/182391-how-bitfenix-cables-work/#findComment-2451027
Thanks :) i know someone that would buy them off me if they weren't extensions anyway :)
|| MAELSTROM ||
https://linustechtips.com/topic/182391-how-bitfenix-cables-work/#findComment-2451052
You should buy an 8pin VGA, a 6pin VGA, 8 pin CPU, and the 24pin mobo connector. I did the same thing for my old rig, look nice,
also you cannot plug an 8pin vga cable into the 6pin on your gpu.
https://linustechtips.com/topic/182391-how-bitfenix-cables-work/#findComment-2451134
i found a 6 pin and all the other stuff i want just need to decide on the colours now :P thanks for all your help
@mapegl finally got around to ordering. this what i want (i get nervous ordering things) the fan splitters are for my dad and if i want to do push and pull later :) lol forgot link https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=331660&action=wish_lists
|| MAELSTROM ||
https://linustechtips.com/topic/182391-how-bitfenix-cables-work/#findComment-2451181
