What CPU cooler Should I get?
Solved by Askew,
Which one is more effective?
H100i, it also moves the heatsink to the edge of the case to have the heat blown straight out, this helps to keep the temperature inside your case down as well as the cpu.
Featured Topics
Alexis-Ms_Sun21 ·
Posted in Troubleshooting0 -
2
Cramig88 ·
Posted in New Builds and Planning6 -
Ghostsanonymous ·
Posted in Displays3 -
1
halfbood_drag0n ·
Posted in New Builds and Planning1 -
7
2
19
