I have a EVGA 780Ti and i just installed it into my PC. i loaded up far cry 3 and put the settings on high and ultra, but the graphics sucked. i installed all the newest drivers for the card and made sure that it was recognized in the bios. when the computer it on the cards fans go on but thats it, the EVGA 780Ti part doesn't even light up. any suggestions?
Processor- Intel i7 4790k Ram- 16GB G.Skill Trident X 2400MHz Motherboard- ASUS Maximus VII Hero GPU- EVGA Geforce GTX 780Ti 3GB Storage- 1TB Western Digital Black + 256GB Samsung Pro SSD PSU- Corsair HX750 Cooling- Corsair H100i
Operating System- Windows 8.1 Pro 64bit Case- Cosrsair Obsidian 450D Display- ASUS VX238H Mouse- Corsair Vengeance M65 Keyboard- CM Storm QuickFire TK
https://linustechtips.com/topic/181848-graphics-card-not-working/
Need the rest of your specs please.
Intel i7 4790k
  • Motherboard
     Asus Maximus Hero VII
  • RAM
    G.Skill Trident X Series 16GB 2400MHz
  • GPU
  • Case
    Fractal Design Define R4
  • Storage
    1TB WD Caviar Black
  • PSU
    Corsair 750HX
  • Display(s)
    Asus 23.5"
  • Cooling
    Corsair H100i
  • Keyboard
    Tt Poseidon Z
  • Mouse
CPU:Ryzen 9800X3D GPU: RTX 5080 MB: Asus ROG X870E  RAM: G.Skill Trident Neo 64gb CPU Cooler: ROG Ryujin III
Intel i7 4790k
ASUS Maximus VII hero (z97)
16gb G.Skill Ram 2400MHz
corsair H100i
corsair hx750
samsung pro ssd 256 gb
1tb western digital black
EVGA 780Ti
Did you plug the 6/8 pin connectors into the GPU? Did you plug your Video cable that goes to your monitor into your graphics card?
yes^
the graphics card is what is sending a picture to my monitor but the in game graphics suck
That makes no sense...  The graphics are the same no matter what video card you are using as long as the settings are the same, the only thing a better video card does is raise frame rates, making higher settings more playable.
thats my problem^ i dont understand why this is happening
First of all, you need to quote people when responding to them so they know you responded.
Second, could you post some screen shots in game?  Also if you have an old graphics card or if your CPU has an iGPU try that and see if the issue persists.
Was it the graphics that sucked or the framerate that sucked?  If it was the graphics itself, could you go into more detail?
i5 4670k (can OC to 4.4Ghz) - Hyper 212 evo w/ AC MX2 - XFX Radeon R9 280X8GB ADATA XPG V2 DDR3-1600 - MSI Z87 G41 - Corsair CX600M 600W PSU - 1TB HDD - 120GB SSD
