Hello fellow LTT members, I'm in need of your help.
For the past week, my internet has been playing up terribly. I can not watch videos at 720p, it even stops at 144p on YouTube....
Webpages take a long time to load, ie, LinusTechTips just took me around 1 1/2 minutes to load, usually loads instantly as i have it set as a secondary homepage.
The problem is, this has been for the past week. Before then, my internet was best that I am paying for, 16Mb down, and unspecified up speeds (usually around 0.7 - 0.9 Mbps), on wireless. I have even tried Ethernet cables and other computers but to no joy. I have a feeling my ISP might be throttling me. (I tend to basically live on YouTube and watch Twitch occasionally)
Is there any way I can tell for definite that my ISP IS throttling me?
Here is a screenshot of a quick speedtest taken around 2AM, well off of peak times.
(In-case the picture doesn't work, here's the link, http://imgur.com/MX7BtqZ )
Thanks for your help.
Also, should mention, checked all the other PC's in the house and nothing is taking up un-necessary bandwidth
Edited by Alexp10v2
Ryze of the Phoenix:
CPU:      AMD Ryzen 5 3600 @ 4.15GHz
Ram:      64GB Corsair Vengeance LPX DDR4 @ 3200Mhz (Samsung B-Die & Nanya Technology)
GPU:      MSI RTX 3060 12GB Aero ITX
Storage: Crucial P3 1TB NVMe Gen 4 SSD, 1TB Crucial MX500, Spinning Rust (7TB Internal, 16TB External - All in-use),
PSU:      Cooler Master MWE Gold 750w V2 PSU (Thanks LTT PSU Tier List)
Cooler:   BeQuite! Prue Rock 2 Black Edition
Case:     ThermalTake Versa J22 TG
Passmark 10 Score: 6096.4         CPU-z Score: 4189 MT         Unigine Valley (DX11 @1080p Ultra): 5145         CryEngine Neon Noir (1080p Ultra): 9579
Audio Setup:                  Scarlett 2i2, AudioTechnica AT2020 XLR, Mackie CR3 Monitors, Sennheiser HD559 headphones, HyperX Cloud II Headset, KZ ES4 IEM (Cyan)
Laptop:                            MacBook Pro 2017 (Intel i5 7360U, 8GB DDR3, 128GB SSD, 2x Thunderbolt 3 Ports - No Touch Bar) Catalina & Boot Camp Win10 Pro
Primary Phone:               Xiaomi Mi 11T Pro 5G 256GB (Snapdragon 888)
https://linustechtips.com/topic/181831-please-help-internet-issues/
Unplug all the cables from your router and plug them back in and then reset your router.
Tried that multiple times, about 5 times today. Its one of the first things that I did when this started happening.
blown your quota/checked your account?
wifi secure?
Is it your account?  If you share with the account holder they can throttle connections from within the router/prioritize traffic.
call your ISP.  They can tell you any interruptions that have happened, and what speeds you should be getting.
CPU: i7 4770K 4.2Ghz, Mobo: Asrock Fatal1ty Z97x Killer, GFX: EVGA GTX 780 Ti SC ACX (x2 SLI), RAM: G.Skill 1600Mhz CAS 9 16GB, DSK Intel 530 120GB OS, Crucial M500 120GB, WD 1TB Blue, WD 1TB Green, PSU: Corsair AX1200i, Case: Obsidian 750D.
SERVER HP ProLiant Microserver N54L, FreeNAS: ZFS, 8TB (4x 2TB WD Red), RAID Z2, 16GB ECC RAM, 1Gb/s Link Aggregated:  Running as NAS, Plex, & ownCloud
