Good lord... Linus has opened pandoras box with the video, finally we can spread even more the gospel of Phanteks.
Yes... I vote Enthoo Pro, never been a fan of the H440.
●CPU: i7-4790K w/H100i ●Mobo: MSI Z97 MPower ●RAM: Corsair 16GB Dominator ●GPU: EVGA ACX SC 780 3GB(X2) ●SSD: 850 Pro 256GB ●Case: 450D ●PSU: AX 860i ●Monitor: Asus PB278Q 1440p
https://linustechtips.com/topic/181516-enthoo-pro-vs-h440/#findComment-2438230
i voted enthoo pro.
i have owned the H440 on day of release and now the enthoo pro on release
and phanteks has pulled a fractal design on the mid-full case platform. easy
price point, many optional choices, air-cooled or water cooled platform case,
and easy on the eyes.
as for comparo to the H440:
pros:
is a larger case
has more water cooling advantages (better than 750D, too)
depending on location a lower price
removable PSU cover
more open intake/exhaust openings
chassis can be deconstructed without rivet drilling
has ODD options
cons:
larger format
no color options
windows really easy to mare/scratch
heavier case
doesn't come with a lot of fans (only two)
could be considered a plastic monger as the roof and front panels are plastical.
https://linustechtips.com/topic/181516-enthoo-pro-vs-h440/#findComment-2439478
Ok thanks, with the money i save on the case i can afford to put in some decent after market fans on the enthoo.I like the look of both but i think ill go entoo because it has better airflow and i think it is super sexy!
† TTCF Member † Jesus loves you! Have a good day and stay techie!
https://linustechtips.com/topic/181516-enthoo-pro-vs-h440/#findComment-2443648
I for sure thought that the H440 master race would kick in on this poll, guess i was wrong.
If you're going for budget and the less hassle of setting up case fans, go for the phanteks. As H440 is more of a mid-tier or not-your-budget-friendly-case. :)
Developer by day, Gamer by night
CPU - Intel i7 4770k | MOBO MSI G45 Gaming | RAM - G.Skill RipJaws X 1600mhz 4x4gb CL7 | CASE - NZXT H440 | GPU - MSI R9 290 | PSU - Corsair RM850 | SSD - Samsung 840 EVO 128gb | HDD - Western Digital Black 2TB
https://linustechtips.com/topic/181516-enthoo-pro-vs-h440/#findComment-2450776
It's funny you say that yet the Phanteks kicks the H440's arse.
https://linustechtips.com/topic/181516-enthoo-pro-vs-h440/#findComment-2450874
Uhm did i say something that "H440 is the better case"? No i did'nt. -.-
https://linustechtips.com/topic/181516-enthoo-pro-vs-h440/#findComment-2450880
