I'm pretty new to water cooling, so it might be a bit of a stupid question, but how often do I have to change the water of my water cooler ?
Do I even have to do it ?
Thanks for your answers !
Silent-Gaming rig- Cpu:i5 4690k // Cpu cooler:Noctua NH-D15 // Gpu:Sapphire R9 290x Vapor-x // Mobo:Msi Z-97 Gaming 7 // Ram:8Gb Corsair Vengeance pro // Case:Phanteks Enthoo Pro // PSU:Corsair RM 650W// SSD:Samsung 840 evo 120gb // HDD:1tb seagate desktop hdd // Display:Asus Vg248qe // Mouse:Logitech G502  // Keyboard:Corsair Vengeance K70 Red-Switches //Audio:HyperX Cloud // and a Mac Book Pro 13'
https://linustechtips.com/topic/181280-water-change/
Is this an AIO or custom loop?
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/181280-water-change/#findComment-2434405
The Corsair H100i
https://linustechtips.com/topic/181280-water-change/#findComment-2434411
never
https://linustechtips.com/topic/181280-water-change/#findComment-2434425
Never, that is why it is called an AIO ( ALL in one system) The coolant that is in the H100i never has to be changed out.
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
https://linustechtips.com/topic/181280-water-change/#findComment-2434429
Ok, thank you !
https://linustechtips.com/topic/181280-water-change/#findComment-2434450
It's called an AIO because everything is all in one(pump/block/tube/radiator/etc)....not because you don't have to change the coolant.  A cooler that was all put together and had the ability to change the fluid(like some newer ones have since they have the ability to expand into a custom loop) are still considered AIO.
But yes...the Corsair H100i does not need fluid changes.  I believe the book states that doing so voids the warranty.
https://linustechtips.com/topic/181280-water-change/#findComment-2434492
I said the same thing just worded it differently, what you said is what i tried to do but in a shorter fashion :)
https://linustechtips.com/topic/181280-water-change/#findComment-2434657
