Hey,
I recently purchased the A2+ s and I really like sound of the mids and highs. They are very detailed speakers and look amazing. However, they do leave something to be desired in the lows. Hence, my question. What sub should I get for the A2+ s. When reading around a lot of people were recommending £300 subs and thats really not what I'm looking for. I just want a sub that compliments the A2+s. The A8 is out of the question due to it's price.
I temporarily stole the sub from a set of Z523s and it improved the sound quite a lot, and the Z523 only cost £70 for the entire set-up. Surely there is a reasonably priced sub out there.
Any recommendations?
Thanks
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/181172-audioengine-a2-subwoofer/
Jbl and velodyne make quality thumpy subs. Polk will make for a better match.
They all seem to be priced at £200 and up in the UK. Which is my issue. Is it normal to pay more for your subwoofer than the speakers?
https://linustechtips.com/topic/181172-audioengine-a2-subwoofer/#findComment-2432913
https://linustechtips.com/topic/181172-audioengine-a2-subwoofer/#findComment-2433151
Do you need the back seat? Can you fit a bigger alternator.
What I meant was, I threw in a 10 inch sub and the cheapest amp I could find, and I have to keep the volume pretty low on the amp.
https://linustechtips.com/topic/181172-audioengine-a2-subwoofer/#findComment-2433279
  • 2 months later...
Yes.
I just got A BK gemni, and dam that thing can punch some stuff. I dont think you will find anything better at the price, and it looks nice.
http://www.bkelec.com/HiFi/Sub_Woofers/Gemini.htm
http://www.whathifi.com/bk/gemini-ii/review
https://linustechtips.com/topic/181172-audioengine-a2-subwoofer/#findComment-3081874
You'll need to find a self powered sub that accepts RCA inputs.
Would this work for you?
http://www.amazon.co.uk/Wharfedale-Diamond-SW150-Subwoofer-Black/dp/B0036EEOSQ/ref=sr_1_5?ie=UTF8&qid=1412092583&sr=8-5&keywords=subwoofer
https://linustechtips.com/topic/181172-audioengine-a2-subwoofer/#findComment-3084023
