So I want to use the pseudo class :hover in my anchor tags but it seems not to be working. I'm using the BRACKETS as a text editor and tried opening it in notepad++ if that helps anything.
------------------------------HTML------------------------------------
<html>
<head>
<link rel="stylesheet" type="text/css" href="css/index.css">
</head>
<body>
<div class="menu">
<ul>
<a href="#"><li>Home</li></a>
<a href="#"><li>About</li></a>
<a href="#"><li>Contact</li></a>
<a href="#"><li>Coming Soon</li></a>
</ul>
</div>
</body>
</html>
-------------------------------CSS-------------------------------------
.menu ul li
list-style: none;
display: inline-block;
.menu
padding-top: 20xp;
height: 30px;
width:100%;
margin-top:30px;
a
text-decoration: none;
border: 2px solid white;
padding: 10px;
color: white;
margin-left: 15px;
.menu ul li a:hover
color:orange;
https://linustechtips.com/topic/181143-newbie-in-css-needs-help/
use the code tag, please
this selector
.menu ul li a:hover
means "the hover of anchors inside LI inside UL inside an element of class menu"
the problem is that
the LI is inside the anchor, and not vice versa (as it should be)
you just need to swap them
https://linustechtips.com/topic/181143-newbie-in-css-needs-help/#findComment-2432614
this selector
.menu ul li a:hover
the problem is that
THANK YOU SOOOOOOOOO MUCH!! Spent so much time figuring out whats the problem>.>
https://linustechtips.com/topic/181143-newbie-in-css-needs-help/#findComment-2432697
