Devices for android development
Solved by Levent,
yup you can use any device for development ,soc maker is not that important unless you are planning on optimizing your games (only thing that it actually makes a difference) for different hardware (tegra soc for example.) .UI doesnt make any difference its all personal preference any android device with armv7 cpu instructions should be good for your needs
