Hey guys, im looking into building my first ever rig and need some advice/suggestions on picking the parts. On a budget of around £1000 ($1700) just for the tower.
I don't require a power supply as in my current pre built system I have added a Corsair 700w GS700 which I will remove at put in my new build.
The aim of this build is for general use like surfing the internet and gaming. Nothing extreme like video editing or anything advanced like that.
I already have a monitor that I am happy at the moment but will be looking to upgrade sometime in the near future once i've got this new rig up and running for a few months.
I already have a gaming keyboard and mouse but I will be selling these to upgrade to better ones once i've got everything built. Only need a new mouse and keyboard not included in the main budget , seperate budget of no more than £150 ($256). I was looking for a mechanical keyboard (not sure which switches) and a new mouse (currently have a wireless RAT9 which I do still like and would keep if I had to but I think my old logitech mx1000 was a better mouse for my uses.
So far I have decided on the following
CPU: Intel i5 3690K
Case: Corsair 450D MID tower
Looking for 8gb of RAM (unless you would recommend more)
CPU cooler (air or all in one water)
Motherboard
GPU (GTX 770 or 780 or any of the AMD equivalents)
500gb SSD as my primary and only drive (have several external hard drives so wouldn't require a HDD)
Would really appreciate any suggestions and advice.
Many thanks.
https://linustechtips.com/topic/179424-first-ever-build/
-snip-
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£161.94 @ Aria PC)
Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard  (£129.53 @ CCL Computers)
Storage: Samsung 840 EVO 500GB 2.5" Solid State Drive  (£183.59 @ Aria PC)
Video Card: Sapphire Radeon R9 290 4GB Tri-X Video Card  (£292.79 @ Aria PC)
Total: £975.82
How to Post Topics, the Right Way / The Ultimate Build Parts List
"4 words. DON'T BE A DUMBASS" ~@Swndlr
https://linustechtips.com/topic/179424-first-ever-build/#findComment-2410573
PCPartPicker part list: http://uk.pcpartpicker.com/p/XJyKK8
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£169.73 @ Overclockers.co.uk)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£24.25 @ Scan.co.uk)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard  (£101.99 @ Ebuyer)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  (£85.45 @ Amazon UK)
Video Card: MSI GeForce GTX 780 3GB TWIN FROZR Video Card  (£339.95 @ Aria PC)
Case: Corsair 450D ATX Mid Tower Case  (£89.99 @ CCL Computers)
Total: £994.95
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
https://linustechtips.com/topic/179424-first-ever-build/#findComment-2410645
And the CPU you mean i7 right?
No I mean i5, for my needs I wouldn't really benefit from an i7 and the money saved can go towards other components.
Total: £975.82
Total: £994.95
Both these look good, defintelly set on the case, CPU and now I think the SSD also as the Samsung 840 EVO 500gb seems perfect for me.
I'm not sure whether to go for an air cooler or liquid on the CPU (i've never seriously over clocked anything before but might be interested in doing it in the future) hence the K CPU
I'd prefer a rather quiet cpu cooler if possible, heard good things about the CM hyper and Noctua.
https://linustechtips.com/topic/179424-first-ever-build/#findComment-2410701
I wouldn't get water cooling unless it's a H100i which is bloody expensive.
https://linustechtips.com/topic/179424-first-ever-build/#findComment-2410719
Would I be limited with CPU cooler height? or does that case allow for plenty of room?
I did like the look of the H100i and I agree it is expensive but seems very simple but then again if im not going to major overlclock i won't need such a good cpu cooler :P
https://linustechtips.com/topic/179424-first-ever-build/#findComment-2410791
Also I forgot to mention I game at 1080p on one display but may look into 1440p if monitor prices drop in the future.
How does the 780 compare against the 290 with its 4gb of VRAM?
About the same in 1080p. 290 around 5fps better in 1440p, but still won't see anything because 60hz.
https://linustechtips.com/topic/179424-first-ever-build/#findComment-2410809
 check this out its an air cooler and i recomend air cooling they come in different colors.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709018
https://linustechtips.com/topic/179424-first-ever-build/#findComment-2410895
Is it not worth choosing AMD over NVIDIA then or would you say NVIDIA has better driver support and features? Plus the extra 1gb vram over the 780 if I go for 290.
I currently have a GTX 560 and can't complain about drivers or NVIDIA software.
https://linustechtips.com/topic/179424-first-ever-build/#findComment-2411037
My Build so Far any input would be appreciated.
Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1600 Memory
Video Card: Asus GeForce GTX 780 3GB DirectCU II Video Card
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer
Need to decide on a motherboard and cpu cooler.
Also as a big lover of windows 7 is it worth upgrading to 8.1 or sticking to 7.
https://linustechtips.com/topic/179424-first-ever-build/#findComment-2414404
How does this look for a build so far? Got all the main components sorted I think.
Type|Item|Price
**CPU** | [intel Core i5-4690K 3.5GHz Quad-Core Processor](http://uk.pcpartpicker.com/part/intel-cpu-bx80646i54690k) | £161.94 @ Aria PC
**Motherboard** | [Asus MAXIMUS VII RANGER ATX LGA1150 Motherboard](http://uk.pcpartpicker.com/part/asus-motherboard-maximusviiranger) | £125.92 @ Aria PC
**Memory** | [Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1600 Memory](http://uk.pcpartpicker.com/part/corsair-memory-cmy8gx3m2a1600c9r) | £65.00 @ Amazon UK
**Video Card** | [Asus GeForce GTX 780 3GB DirectCU II Video Card](http://uk.pcpartpicker.com/part/asus-video-card-gtx780dc2oc3gd5) | £347.74 @ Scan.co.uk
**Case** | [Corsair 450D ATX Mid Tower Case](http://uk.pcpartpicker.com/part/corsair-case-cc9011049ww) | £89.99 @ CCL Computers
 | | **Total**
 | Prices include shipping, taxes, and discounts when available | £790.59
https://linustechtips.com/topic/179424-first-ever-build/#findComment-2421770
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (Purchased For £167.99)
Motherboard: Asus MAXIMUS VII RANGER ATX LGA1150 Motherboard  (Purchased For £129.99)
Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-2133 Memory  (Purchased For £68.06)
Storage: Samsung 840 EVO 500GB 2.5" Solid State Drive  (Purchased For £164.14)
Video Card: Asus GeForce GTX 780 3GB DirectCU II Video Card  (Purchased For £353.99)
Case: Corsair 450D ATX Mid Tower Case  (Purchased For £91.99)
Total: £976.16
Now just need a cpu cooler, optical drive and a copy of windows.
https://linustechtips.com/topic/179424-first-ever-build/#findComment-2441575
