What would be a good cooler for the 4790k? I don't want water cooling btw. My case is the Nzxt Phantom 410 btw.
I've narrowed choices down to some.
Noctua NH-D14
NZXT Havik 140
CM Hyper 212 Evo
And any others that can be recommended for a cpu that runs this hot.
Also recommendations are very much appreciated, thanks!
https://linustechtips.com/topic/179108-4790k-air-cooling/
id go with the noctua one if youre planning to oc
Corsair C70|i7 3930K|Corsair Vengeance 16GB 1600Mhz|Asrock x79 Extreme6|Samsung SSD 256GB|WD Green 3TB|Corsair H100i|Corsair TX750m |GTX 780 Palit Super JetStream (review here https://linustechtips.com/main/topic/54814-palit-gtx780-superjetstream-review/ )  -_-|
STILL LEARNING ENGLISH  :P  :P  :P
https://linustechtips.com/topic/179108-4790k-air-cooling/#findComment-2405916
Noctua NH-D14
NZXT Havik 140
CM Hyper 212 Evo
What ram do have?
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/179108-4790k-air-cooling/#findComment-2405963
If you don't want to do any overclocks that would be considered more than mild than you'd be fine with the 212 EVO, I'd stay away from the Havik 140 as it is super large and pretty annoying to work with.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/179108-4790k-air-cooling/#findComment-2406133
Noctua gets my vote.
CPU: Intel I7-4790k | MOBO: Asus Sabertooth Z97 Mark 1 | Ram: Corsair Vengance 32GB 1600hz | GPU: EVGA GTX980 Reference
PSU: Corsair EVGA G2 850W  | SSD: Intel 730 Series 480GB, Kingston SSDNow V300 120GB | HDD: WD Black 1TB
 CPU Cooler: Corsair H105 | Case: Corsair 760T (White) | Peripherals: (2)Asus VS247H-P, Corsair M65, Corsair K70 RGB w/ Brown Switches
https://linustechtips.com/topic/179108-4790k-air-cooling/#findComment-2406169
I have low profile g skill ares ram
In that case Defo get the d14
https://linustechtips.com/topic/179108-4790k-air-cooling/#findComment-2406216
Noctua NH-D14
NZXT Havik 140
CM Hyper 212 Evo
I would go for a Noctua NH-U14S....
It's Cheaper looks better and takes up less room, It works just as good as the Noctua NH-D14 if you add an Extra fan.....
I have one and would Recommend 100%.
https://linustechtips.com/topic/179108-4790k-air-cooling/#findComment-2406487
Thanks everyone. It just sucks trying to save money, so the Noctuas are definitely under consideration!
I'll also be using the Arctic cooler mx-4 thermal compound as I hear that's good!
Unfortunately the Noctuas cover up ram slots and it seems inconvenient to take out the cooler if i want to insert more ram later on
https://linustechtips.com/topic/179108-4790k-air-cooling/#findComment-2406652
The NH-U14S dose not cover your RAM at all.....
What mother board do you have..?
https://linustechtips.com/topic/179108-4790k-air-cooling/#findComment-2406677
Asus Z97-AR.
How much better would the NH-U14s be over the Hyper 212 Evo?
It's Much much better... It's the best single tower on the market. put a second NF-A15 on it and it's there with the H100i just a few C's Higher in temps.
And with that Mother board it's 100% compatable... With RAM and Graphics Card
https://linustechtips.com/topic/179108-4790k-air-cooling/#findComment-2406940
You don't need to buy thermal compound if you get Noctua. You get their branded one with cooler. Its as good as any other on the market.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/179108-4790k-air-cooling/#findComment-2411720
