Okay so Im trying to setup Netflix for my dad and my brother to my 360 and Wii, so the issue is im assuming that it will not work with any console, it works with all mobile devices, my HTC One, my Brothers Nexus, and my Nvidia Shield, although when it comes to the Wii it will say its connected, launch Netflix and it doesn't work it gives me some error (I forget it) but I googled it and it said to manually input the configuration to access my network so I did and nothing so I pulled my old Xbox 360 (its the Slim) from my closest and my XBL Account still has Live on it but nevermind that because its not the issue, it says it cannot connect to Xbox Live or establish a connection so I went into the setting and disconnected from my Network re-connected (note that I had 3 of 5 bars of signal strength according to the console (I got a Dual Band Router (router will be listed at the bottom of the page)) but it doesnt even detect a connection
My Router:
SURFboard eXtreme All-In-One Wifi 802.11ac DOCSIS 3.0 Internet Cable Modem
http://www.amazon.com/SURFboard-All-In-One-802-11ac-Internet-SBG6782-AC/dp/B00F3JI47Y
https://linustechtips.com/topic/178841-connection-help/
