adsl modem issue
Solved by d3sl91,
hi,
my adsl modem often has problems conecting to the internet because of the low bandwith comming from the phone cables, does anyone have a solution for this issue like a modem optimised for shitty conection that will keep the internet on all the time or something?
please help
(my isp sucks they will never help me with this issue, tried contacting them many times)
If you have bad connection because of your phone lines in your house, not much you can do other than run a brand new phone wire directly from the box outside to your modem and see if that helps.
Also make sure you are running filters on everything.
