About 4-5 times a month the power will go out for a second and then back on causing my computer to power cycle. I am forced to unplug it and hold the power to drain the power or I will have USB issues throwing up a BSOD. Not to mention I lose all my work unless i save it beforehand. Would a UPS be able to handle an instantaneous on/off? If so, what are some recommendations? $200 is my budget.
Main: i7 2600 | ASUS P8Z68-V | 2x4GB Vengeance 1600 | GTX 580 | WD Blue 1TB | Antec TP-650C | NH U12S | W7 x64
Backup: X6 1090T | MSI K9A2 Platinum | 4x2GB XMS2 800 | GTX 550Ti | WD Blue 1TB |  Antec VP-450 | CM TX3 | W7 x64
https://linustechtips.com/topic/178557-uninterruptible-power-supply/
Spend it on a UPS. It will be perfectly fine with quick on/off as long as it has an equal or greater wattage than your whole PC
My Stuff! :D
My Stuff
  • Main Build - Soon to change due to it being dead
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 16GB Corsair Vengance  Blue LP 1600Mhz
  • 120GB Samsung 840
  • 2TB Seagate Barracuda
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • Bitfenix, Corsair, and Darkside cable extensions
  • Das Professional with Cherry MX Brown's & Custom Keycaps
  • 3x ASUS VS238H-P w/ Triple monitor mount in PLP
  • AudioTechnica ATH-M50's
  • Blue Yeti Microphone
  • TurtleBeach PX3 Wireless
  • Logitech C920 Webcam
  • Precision Audio Bookshelf Speakers
  • AudioSource AMP-100
  • Logitech G27 Racing setup
  • Laptop - Acer 7750G-9855
  • i7 2630QM
  • AMD 6650M GPU
  • 120GB Samsung 840 EVO
  • 8GB RAM
  • Operating System: Windows 7 Home Premium
  • Blu-ray Drive
  • Netbook - HP Pavillion DM1
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • Cell Phone - OnePlus One
  • 5.5-inch 1080p Screen
  • Qualcomm Snapdragon 801 processor @2.5Ghz
  • 13 Megapixel rear camera
  • 5 megapixel wide angle front facing camera
  • 3100 mAh non-removal battery
  • AC wifi
  • Cell Phone #2 - Nexus 5
  • 5 Inch 1080p Screen
  • Snapdragon 800
  • 8 megapixel rear camera
  • 1.3 megapixel front camera
  • 2300 mAh non-removable battery
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
  • 1x 1440 or 1600p Monitor
  • Das Mechanical Keyboard
-snip- Not to mention I lose all my work unless i save it beforehand. Would a UPS be able to handle an instantaneous on/off? -snip-
as long as its the power drops for less than 10 minutes, you can have quite a light UPS.
we (not me) could help you better if you told us what your wattage is of your computer and all the other things you want to connect to the UPS (such as monitor, ... )
to calculate the capacity of your UPS: power draw (in watts) * maximum time and some extra time (in hours) = watt in an hour -> Wh or kWh (kWh = Wh *1000 )
Edited by darkspeedy26
build log: diagonalmod (RIP?)
i know i use many of these: ( ) and these: ... (i really do... (sry...) ) edit: and edits
