Best Peripherals for me
Go to solution Solved by Verne,
What is your budget?
G502 is an excellent mouse. For big hands there are also SteelSeries Rival and Mionix Naos 7000. For a mouse pad, do you want hard or soft or hybrid? Glide or control? For a hard pad I would recommend SteelSeries 4HD/9HD, for soft Puretrak Talent or Roccat Taito and for hybrid Zowie P-TF Speed.
CM Storm and Ducky keyboards come in many sizes and color and well-built and should be easy to find. Some more preferences would help, such as switch preference, back-lighting yes/no/color, size.
On audio side, Superlux HD668b or HD681 EVO headphones + Zalman ZM-MIC1 clip-on microphone is superb budget combo. Other options for headphones you could consider are Pioneer SE-A1000, CHC Silverado, Sennheiser 518/558 or just check the audio sub-forum. For a microphone Modmic is a better clip-on mic and Blue Snowball is a good cheap desktop mic.
If you must have a headset then Kingston HyperX Cloud (or Qpad QH-85 or QH-90) would be a good starting point with Sennheiser G4ME One/Zero headsets being the next step up, then Audio-Technica AG1/ADG1 and Beyerdynamic MMX-300 in the next tier.
So im looking into some some peripherals, and i was wondering what would be the best mouse, keyboard, mousepad, headset for me. I got a huge head, Huge hands and use my right hand for a palm grip for  a mouse. i was thinking of getting a goliathus mousepad extended, but my table wont fit that, and im pretty set on getting a g502 for the mouse, but i was wondering if there are any better options for me
https://linustechtips.com/topic/178530-best-peripherals-for-me/
https://linustechtips.com/topic/178530-best-peripherals-for-me/#findComment-2397830
Forgot to add, i could really care less about the numpad, i dont use it but to me w/o it it seems weird to me, but i can deal with it. I play with a low sensitivity, and i was thinking of pairing up the pioneers with a blue snowball recommended from the post above
https://linustechtips.com/topic/178530-best-peripherals-for-me/#findComment-2398759
