I'm constantly looking for the solution to my problem. Its becoming a problem to me and its worrying. I don't know what to do, does this build look good?http://pcpartpicker.com/user/godlycam/saved/qjZzK8
I am constantly on the internet searching and searching and want to rid the headache and constant worry about something as little as... A GPU. I just want at least 60 fps all the time, don't care if it dips a little. I want to play BF4, watch dogs, Minecraft w/ shaders, far cry 3 etc.. I hate stressing over this, I want something like shadowplay because I want to record so preferably nvidia. I can't go over 1200 or maybe even 1150.. I don't know.. Just don't want to be stressed and worried and doing nothing but searching. I'm not a loser or anything as I'm athletic and stuff but I'm just stick in a huge bind. Thanks for all responses. :)
https://linustechtips.com/topic/178446-i-have-a-problem/
Haha paranoia
Oh you're fine.
(Already bought) inwin gt1
Alright. Well for starters the 8150 is a bit dated, you're better off going with the 8350. You've got a really solid build to start with though. You can get an R9 290 cheaper than a 780 and it performs a little bit better. So far I've shaved $100 off of the final price for you. :) Also, the Kingston V300 is a pile now because they changed the firmware on it so it's super slow compared to what it used to be. This is the list that I've come up with:
CPU: AMD FX-8350 4.0GHz 8-Core Processor  ($174.99 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ Amazon)
Motherboard: Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard  ($64.99 @ Micro Center)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory  ($74.99 @ Micro Center)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  ($67.98 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($52.92 @ Amazon)
Video Card: Sapphire Radeon R9 290 4GB Tri-X Video Card  ($369.99 @ Amazon)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($99.98 @ OutletPC)
Total: $1015.82
https://linustechtips.com/topic/178446-i-have-a-problem/#findComment-2396043
Oh you're fine.
Total: $1015.82
Thanks a lot. :) is there a feature like shadowplay for amd?
https://linustechtips.com/topic/178446-i-have-a-problem/#findComment-2396056
There should be yeah. But you really shouldn't start planning for a build until you have the money. You never know what will change with prices.
just as long as he can get the money for it. Im building my own pc and im buying them each when they are at their lowest price
helps alot so you can see most major stores prices and a graph of which shows you when prices can go up or down....
hint beginning of months are cheaper from what ive seen
| Ryzen 9 3950X | EVGA 1200P2 | AMD 5700XT | ASUS Crosshair VIII Hero WiFi | G. Skill 4x16GB 3600Mhz CL16 F4-3600C16D-32GTZN | 2x1TB Samsung 980 Pro | Lian Li O11 Dynamic |
https://linustechtips.com/topic/178446-i-have-a-problem/#findComment-2396194
