You cant. you have to do it by hardware if its the case fans. cpu fans can be done by overclocking also gpu can be done by oc too.
EDIT: By hardware i mean, like fan controller speeds. I got mine built in case! Dazumba Rocks!!!
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
https://linustechtips.com/topic/178116-fan-control/#findComment-2391196
fans plugged to mobo, then use software, or stuff that comes with some mobos, like in bios
yeah but some are not connected. Back fans, and cpu fans usually are the one connected to mobo
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/178116-fan-control/#findComment-2391230
depends on mobo. some have multiple chassis fan headers
indeed.
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/178116-fan-control/#findComment-2391308
Just get a fan controller, they arnt that expensive and are the most simple option.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/178116-fan-control/#findComment-2394072
Depends. For most feature rich though not accurate, use mobos own software. For 4pin fans, Speedfan, also if you like to use curves. For 3pin fans and constant rpm, OpenHardwareMonitor.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/178116-fan-control/#findComment-2398220
