What country?
If you're buying reference I'd go with EVGA in almost all circumstances unless you are in Asia.
Ok thanks. :) thats what I was getting anyway but I just wanted to make sure.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487001&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
https://linustechtips.com/topic/177390-reference-780ti/#findComment-2380469
Nice choice, if the regular (non superclocked) is cheaper then consider getting that and overclocking yourself, buying the superclocked one doesn't guaruntee higher overclockability over the standard one, and chances are the standard one will clock higher than the factory overclock on the superclocked edition anyway.
https://linustechtips.com/topic/177390-reference-780ti/#findComment-2380514
WOW, $720 for a reference 780 Ti???? Also I'd just like to point out that Newegg is high.
http://www.newegg.com/Product/Product.aspx?Item=9SIA49E1MM8481&cm_re=gtx_780_ti-_-9SIA49E1MM8481-_-Product
If you get more than 1,000 of these you can save yourself $167.65 on each!!!! I'd like to know why the hell that is!?!?!?!
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/177390-reference-780ti/#findComment-2380567
Insane sli setup of course. :P
If only.
https://linustechtips.com/topic/177390-reference-780ti/#findComment-2380690
why a reference card?
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/177390-reference-780ti/#findComment-2381065
Watercooling
Well EVGA told me if I take off the stock cooler and the card dies within the warranty period from something I didn't do, then their warranty is still valid as long as the card is returned to them with the original cooler. I haven't checked with any other company they may be same though.
https://linustechtips.com/topic/177390-reference-780ti/#findComment-2387313
