Hi
i have some questions about the bitfenix prodigy.
i will be installing 2 h55s in it and i was wondering if you could fit 2 h55s beside each other on the top 2 120mm slots and can you still fit a fan controller if you do so?
thanks
My setup
CPU i7 4770K 4.8 ghz 1.4V Motherboard MSI G-45z87 RAM 32gb 1600mhz hyperx ram GPU 3x Gtx 780ti Windforce GHZ edition Case NZXT Phantom 820 Storage 64gb SSD and a 500GB HDD PSU corsair ax1200i Display(s) 3x Acer S231HL Cooling h105 8 corsair af 120
https://linustechtips.com/topic/177177-bitfenix-prodigy-help/
I don't think they will fit side by side because of the reservoir and tubing coming out of opposite sides. Why don't you just use an H100 or other 240mm AIO cooler?
Also I don't think you can fit a fan controller if you have a radiator and a fan in the front (top) 120mm fan mount. But you can get external fan controllers, I believe NZXT make one.
My PC:
4670k      GTX 760 ACX      CoolerMaster Hyper 412s      Fractal Design Node 804      G1 Sniper M5      Corsair RM 650      WD Red 1TB     Samsung 840 Evo 120GB
https://linustechtips.com/topic/177177-bitfenix-prodigy-help/#findComment-2377246
Mounting them sideways should be fine.
As for the fan controller, I do not know.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/177177-bitfenix-prodigy-help/#findComment-2377324
Hi
thanks
I assume you mean a fan controller that fits in the 5.25" drive bay? It won't fit. Using the full 2 x 120mm fan/rad space the Prodigy has in the top means removing the 5.25" drive bay.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/177177-bitfenix-prodigy-help/#findComment-2380559
