here is a link for the new parts i have ordered which have been delivered over the last 3 days http://pcpartpicker.com/p/HLPmFT.
I have struggled over the last couple of hours with not much information from the suppliers i have bought from, however i think i i have got it all sorted. Its just that i have 3 more cables to link up to something and i dont know where they go. Any help would be appreciated
thanks.
The cables are all coming from the case its self and all have 1 or 2 very thin leads with a square socket on the end... these are
power Sw
H.D.D. Led
Power LED +
Power LED -
CPU: I5-4440 / MOBO: Gigabyte GA-Z87-DS3H / RAM: G.Skill ripjaws 2x4GB / Storage: Samsung 840 EVO 128gb SSD, 1TB WD HDD / PSU: Corsair CX500M / Case: Xigmatek Aquila / Monitor: Dell U2414H
https://linustechtips.com/topic/177034-help-last-few-cables/
Thx for the reply. The case manual does not explain it very well is says i/o switch and chassis led installation. the motherboard manual says nothing. you could be right that i dont need them however the power Sw lead is the on/power button on the case so im sure that has to go somewhere.
Anyone have any ideas?
https://linustechtips.com/topic/177034-help-last-few-cables/#findComment-2375061
