Cooler Master V450
Go to solution Solved by MegaDave91,
Assuming it will fit, yes.
https://linustechtips.com/topic/176611-cooler-master-v450/#findComment-2367845
It is going in the Elite 130 so it should fit?
Looks to be no problem.
https://linustechtips.com/topic/176611-cooler-master-v450/#findComment-2367870
