Something like this should do it.
PCPartPicker part list: http://pcpartpicker.com/p/n3cQf7
Price breakdown by merchant: http://pcpartpicker.com/p/n3cQf7/by_merchant/
CPU Cooler: be quiet! Shadow Rock Slim 113.8 CFM Rifle Bearing CPU Cooler  ($29.99 @ NCIX US)
Motherboard: ASRock Z97 PRO4 ATX LGA1150 Motherboard  ($109.99 @ Newegg)
Total: $139.98
Getting a locked i5, with a H81/H87/B85/H97 motherboard, will be cheaper, and perform better overall.
https://linustechtips.com/topic/176575-motherboard-cooler/#findComment-2367972
Total: $139.98
for pure gaming, doubt it.
https://linustechtips.com/topic/176575-motherboard-cooler/#findComment-2368057
On the large majority of games, GPU is the deciding factor, you could spend your money on a i3 and a cheap motherboard and have only 1-3 fps difference with a more expensive and overclocked CPU.
If the game does benefit from the CPU, it's all about how optimized it is. If the game can make 4 cores work, then the locked i5 will perform better than the OC'ed pentium K. More gigahertz doesn't mean more performance.
On other games, that are CPU bound and poorly optmized (only use one core), like MMOs, and games like Starcraft II, the Pentium chip, if well OC'ed, can overcome other CPUs. Either way you go, with your system you are still getting 60fps+ on those games anyways.
I still prefer a processor that will allow me to do other stuff, computing wise the i5 is better, and even for multitasking it is. I like having 2 monitors, and while gaming still do plenty of stuff at the same time. Having the extra cores can make a difference, specially if you are streaming.
https://linustechtips.com/topic/176575-motherboard-cooler/#findComment-2368319
