I am able to get a reference hd 7970 for around $320 or a hd 7950 for around $290 (non reference, Ex: XFX Core edition)
Which would be the better option for triple monitor gaming (5760x1080), for noise, performance, temperature, etc?
Thanks in advance.
MSI R9 290 Gaming | MSI Z77 MPower Big Bang | XFX Pro 750W Black Edition | i7-3770k @ 4.5GHz | Corsair H100i | GSkill Ripjaw 2x8Gb | NZXT Phantom 410 Gunmetal | OCZ 128 Gb Vertex 4 | Samsung 250Gb 840 EVO | 1&2 Tb Seagate Barracuda | Logitech G510 | Logitech G700 | Logitech G35 | 3 x LG E2442V
-it24-
https://linustechtips.com/topic/17607-radeon-7950-vs-7970/
What if i spent a bit more to get a better cooled 7950? Or is the 7970 still the better choice?
-it24-
https://linustechtips.com/topic/17607-radeon-7950-vs-7970/#findComment-203127
7950 Boost could be an option, overclocked they can match the 7970 :)
Akula  | Dimastech Test Bench | Watercooled | Tri GTX 680's | Build of the Week
Mercury | Caselabs Mercury S3 | Watercooled | GTX Titan | Build of the Week
Armada | Define R4 Titanium | Watercooled | EK Waterblocks | Newest Buildlog
https://linustechtips.com/topic/17607-radeon-7950-vs-7970/#findComment-204451
That's a great price on a 7970 but I'd personally stay away from reference.  They have horribly hot and loud coolers on them.  Try to find a good price on a non-reference cooler 7970 like a Twin Frozr or Dual-X from Sapphire...
Intel Core i7 4930K @ 4.7GHz | Asus Rampage IV Extreme | 2 x EVGA GTX Titan SC (1254MHz) | 16GB Patriot Viper Extreme DDR3 2133MHz (4 x 4GB) | Corsair AX1200 | Silverstone Temjin TJ11 | Corsair Force 3 240GB (System) | 2 x Intel 320 160GB SSD (Dedicated Gaming Drives) | Hitachi Deskstar 1TB (Data) | MS Windows 10 Pro | EK Supreme HF/FC-Titan/Rampage IV Extreme blocks | Hardware Labs GTX 560/240 rads | Alphacool VPP-655 D5 pump | Bitspower mod kit/pump top/fittings/120mm res
https://linustechtips.com/topic/17607-radeon-7950-vs-7970/#findComment-204487
I agree with mega in that you should try to stay away from reference coolers as they - well they suck. If you can't find a good deal on a non reference 7970, you can overclock a 7950 to meet/pass the performance of a 7970.
Me: Yeah I just really can't get my H220 working again, I've tried everything that was suggested in the forum.
Brian (Swiftech Support): Hmm, have you tried slapping it?
https://linustechtips.com/topic/17607-radeon-7950-vs-7970/#findComment-204497
get the reference 7970 and watercool them. :D
https://linustechtips.com/topic/17607-radeon-7950-vs-7970/#findComment-205001
i'm going to say 7970 even though everyone else already did because i can.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/17607-radeon-7950-vs-7970/#findComment-205009
