Not reaching the optimal Read/Write speed
Solved by vorticalbox,
I could chose between::
IDE mode
Raid
AHCI
I chose AHCI and i just got bluescreened after the windows logo, before login.
1. Startup "Regedit
2. Open HKEY_LOCAL_MACHINE / SYSTEM / CurrentControlset / Services
3. Open msahci
4. In the right field left click on "start" and go to Modify
5. In the value Data field enter "0" and click "ok"
6. exit "Regedit"
7. Reboot Rig and enter BIOS
then change to ACHI and reboot.
