Help me upgrade (for cheap)
Go to solution Solved by SpecTre12345,
The gtx 660 looks really good considering its 140 with the rebate and comes with watch dogs but would it be better to just pay the extra $25 for the r9 270x?
You're not going to be able to play Watch_Dogs on a GTX 660, go with the 270x
This is my first post on linustechtips so i hope i'm on the right thread!
Hey guys, my brother has had his pc since about 2009 or 2010 and is looking to upgrade. Better fps in games is the primary motivator for the upgrade so i was considering a new graphics card. I've heard the 7950 would be a good upgrade but i was also considering a GeForce GTX 750 Ti see as how it wont use a lot of power. I was also worried that the cpu would bottleneck any new graphics card i would be willing to get but i'm not sure if that would be a problem.
BTW, im in college right now so money is a bit of an issue. my max amount for a new graphics card would be $200 but i would definitely prefer to stay near $150.
Windows 8.1 Pro 64-bit
AMD Phenom II X4 945 Processor (4 CPUs), ~3.0GHz
4096MB RAM
AMD Radeon HD 5770 graphics card
He uses a 1280 x 1024 monitor which isn't HD, its an old 4:3
https://linustechtips.com/topic/175648-help-me-upgrade-for-cheap/
What is the PSU in the system? If it's 450w or lower, you may run into problems running a 7950 or something similar. If you don't want to pay for a new PSU, the 750 Ti is a nice option. I have one myself. However, at such a low resolution, both cards will perform excellently, even when you decide to upgrade to a more modern resolution like 1920x1080. I don't believe you will experience any bottlenecks with the two cards, but a CPU upgrade she be in order if you ever decide to go even higher.
Build: CPU: Intel Core i5 4690k | CPU Cooler: Hyper 212 Evo | Motherboard: MSI Z97 Gaming 5 | RAM: 8GB G-Skill Ares 1600Mhz CL9 | Storage: 120GB Samsung 840 Evo + WD Blue 1TB 64MB Cache + Seagate Barracuda 2TB 64MB Cache | GPU: MSI GTX 960 | Case: Cooler Master Storm Enforcer | Power Supply: EVGA 600B Non-Modular |
better monster and then a 7950
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
Hes got an ocz 500w power supply
For the best performance under $200 (considering you're in the US), the
R9 270x:
http://pcpartpicker.com/part/sapphire-video-card-100364l
750 Ti:
http://pcpartpicker.com/part/msi-video-card-n750titf2gd5oc
660:
http://pcpartpicker.com/part/msi-video-card-n660gaming2gd5oc
7870:
http://pcpartpicker.com/part/powercolor-video-card-ax78702gbd52dhv5eoc
That's the best I found under $200. Out of all of them, the R9 270x will perform best. Sorry again if your location was wrong, it wasn't specified in the OP.
4096MB RAM
Get yourself a nice cheap monitor with decent specs, it will enhance your experience so much. I did a quick search and found this, it's £115 here in the UK, so I'm not sure what it is in USD but here you go
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16824009422
CPU  Intel i7 5820k Motherboard Asus X99-S  RAM  32GB (8x4) Kingston Hyper X Fury GPU EVGA GTX 1080Ti SC2 iCX Case Fractal Design R4 Windowed Storage 500GB Samsung 850 Evo + 120GB Crucial M500 SSD + 2TB Seagate Barracuda + 1TB Western Digital Blue PSU Corsair RM1000 Display 2x Asus VS239HV Cooling  Noctua NH-D15 Keyboard  Corsair K70 RGB Mouse Logitech G502 Gaming Surface Razer Golitahus Extended Speed
R9 270x:
750 Ti:
660:
7870:
