So the modem isn't showing any indication lights?
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
https://linustechtips.com/topic/175419-reciver-problem/#findComment-2342044
Test your ports, or call your isp and tell them to refresh your ports.
There is other things you can try. Unplug both the modem and your router for 15 seconds.
https://linustechtips.com/topic/175419-reciver-problem/#findComment-2342124
Do you rent or own the modem?
https://linustechtips.com/topic/175419-reciver-problem/#findComment-2342211
