Hello guys, i am planning saving for an awesome watercool rig but the problem is that i dont know much about watercooling
i want to make a build similar to this: Snef's build and http://www.million-dollar-pc.com/systems-2010/renovatio/038.htm
snef;s build:13626850625_619906bf26_o.jpg
What hardware:
since i will be using it as a workstation and gaming pc
cpu: i7 4930K
gpu: maybe 2 r9 290x or even 1 r9 295x2 if possible watercool it
ram: cheapest 32gb
hd: 2 drives western digital 2T
ssd: 512 gb ssd X 2
case: Big problem  dont know either the caselabs or the other one
but what i need is a window so i can show the pumb
motherboard: Rampage VI BLACK EDITION - OR A CHEAPER ONE
I just want to see the price with the help from you guys
https://linustechtips.com/topic/175321-help-with-this-build/
that rig
blood red and white
are you trying to replicate that build?
suggest going to ask the questions in the water cooling sub forum
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/175321-help-with-this-build/#findComment-2340185
that rig
blood red and white
i am not trying to replicate i am trying to make a similar one with similar features and some differences
I would private message @Snef and see if he can help out seeing as that is his build.
Thanks i will ask him now, if he could help me out
https://linustechtips.com/topic/175321-help-with-this-build/#findComment-2340220
What hardware:
cpu: i7 4930K
ram: cheapest 32gb
ssd: 512 gb ssd X 2
im happy to help you
I will answer your questions the best I can
That build is disgusting. Looks plastic, and two reservoir's looks bad as hell.
all tastes are specific to each
I can not build a pc that everyone loves
but im very curious to see your build? any build logs or pics of your
My Build Logs
Snef Bloody Angel --- Sand of God --- Red Poseidon --- Purple Chimera BOTM July 26 2013 --- Icy Blue Angel BOTM May 10 2013 --- Extremmme Red DemonBOTM March 29 2013
https://linustechtips.com/topic/175321-help-with-this-build/#findComment-2340507
I'm not saying my build looks nice either.
Here is mine btw:
https://pcpartpicker.com/b/RyvKHx
"If violence does not work, try more violence"
https://linustechtips.com/topic/175321-help-with-this-build/#findComment-2340524
