i just finished my new build and have a question/problem?
Sabertooth z97 mach 1
i7-4790k
asus gtx 780 CU ii OC
16GB Dominator 1866 RAM
win 8.1
liquid cooled CPU
RM 750 PSU
Minor OC to CPU and Mem
I ran Cinebench 15 and my scores where great. next i ran 3DMARK Advance on the extream test settings and my score was X4480
Graphics Score=   4134
Physics Score =  10314
Combined Score= 5003
Looking at other scores with the same setup and the are much higher. Any Ideas?
https://linustechtips.com/topic/175281-new-build-problem/
i7-4790k
win 8.1
liquid cooled CPU
RM 750 PSU
since its a new build, are you running the latest drivers?
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/175281-new-build-problem/#findComment-2339492
THIS IS THE OTHER INFO FROM 3DMARK11.  one thing i do see is it has my memory listed as 667 Mhz is that a problem? i know its listed right in the bios and AI 3   Graphics Card NVIDIA GeForce GTX 780 Vendor Asustek Computer, Inc. # of cards 1 SLI / CrossFire Off Memory 3,072 MB Core clock 889 MHz Memory bus clock 1,502 MHz Driver name NVIDIA GeForce GTX 780 Driver version 9.18.13.4043 Driver status FM Approved     Processor
Intel Core i7-4790K Reported stock core clock 4,000 MHz Maximum turbo core clock 4,589 MHz Physical / logical processors 1 / 8 # of cores 4 Package LGA1150 Manufacturing process 22 nm TDP 88 W
General Operating system 64-bit Windows 8.1 (6.3.9600) Motherboard ASUSTeK COMPUTER INC. SABERTOOTH Z97 MARK 1 Memory 16,384 MB Module 1 8,192 MB Corsair DDR3 @ 667 MHz Module 2 8,192 MB Corsair DDR3 @ 667 MHz Hard drive model 250 GB Samsung SSD 840 EVO 250GB
https://linustechtips.com/topic/175281-new-build-problem/#findComment-2339515
run prime 95 and fur mark for an hour or two and burn in the system this sometimes helps with performance a bit also it could just be bad luck getting lower performance parts than others, some cpu's and gpu's just performe better than other chips of the same model
https://linustechtips.com/topic/175281-new-build-problem/#findComment-2340975
