this was my first anti-virus back in 2012 then i tried eset and when the trial ended i installed the new avg. its always like this for the last 8 months. what should i do?
AMD Athlon 64 x2 3600+ | Asus M2N68-AM SE2 | 3gb ddr2 | Orion 600w | Sapphire HD5570
https://linustechtips.com/topic/17519-help-avg-error/
uninstall and try reinstalling? never sen that error been using avg sence 98se
Main Rig: CPU: 3570k Mobo: ga-z77x-ud5h-wb :RAM: 8gb kingson ddr3 1600 :gpu crossfire amd 290's Case: zalman z9 plus Cooler: h80i p/p SSD: nutron 120gb HDD: 2tb wd green 4tb seagate desktop
Girlfirends: CPU: 8350 Mobo 990fxa-ud3 Ram 8gb kingson ddr3 1600 gpu: his 7850 case: inwin dragon rider SSD: nutron 120gb HDD: 2tb seagate
https://linustechtips.com/topic/17519-help-avg-error/#findComment-201986
have you tried running as admin?
and any other hdd you could try installing it to?
have you tried redownloading the installer it self?
https://linustechtips.com/topic/17519-help-avg-error/#findComment-202026
no(gonna try this)
no(gonna try this)
yes
Edit: it automatically runs as admin.
https://linustechtips.com/topic/17519-help-avg-error/#findComment-202039
try installing it into a diffrent directory? like c/avg insted of c/programfiles/avg/ ???
https://linustechtips.com/topic/17519-help-avg-error/#findComment-202047
no luck
now its downloading the files fast then going back to zero.
https://linustechtips.com/topic/17519-help-avg-error/#findComment-202104
hmmm weird i am out of ideas my next pick would be avast its lighter on resorses and i find just as good but ive used avg for so long i dont want to swich personly
https://linustechtips.com/topic/17519-help-avg-error/#findComment-202110
yeah, i feel like i'm safer with avg. right now i'm downloading the offline installer and see if that works.
https://linustechtips.com/topic/17519-help-avg-error/#findComment-202204
actuly forgot about the offline instaler nice work on trying that
https://linustechtips.com/topic/17519-help-avg-error/#findComment-202215
Just decided to go with avast. i was surprised about the talking girl.
thanks for the help.
https://linustechtips.com/topic/17519-help-avg-error/#findComment-202574
no problem
https://linustechtips.com/topic/17519-help-avg-error/#findComment-204755
