BF4 AND Titanfall launch/load problems
Go to solution Solved by Ryoku,
try the crash fixes for BF4 on this reddit post.
http://www.reddit.com/r/Battlefield/comments/1q14u9/bf4_i_have_multiple_fixes_that_make_the_game_90/
Also use the newest Nvidia drivers, make sure to do a clean install.
Getting some serious problems with BF4 and Titanfall. First off i have tried most NV drivers within a 6 month time period. Second of all I have re installed and repaired both games multiple times. BF4 is located on my 840 EVO serving as my C drive with Titanfall on my mechanical HDD serving as E drive.
Here's the problem with BF4: When i join a server or launch the campaign the game loads but it never gets past that. When i open task manager the game stays in the background processes and doesn't move to the current running processes or Apps as Win8.1 PRO calls them. Re-installed Punkbuster as well. Nothing has worked for me.
Titanfall is the same story except it doesn't even get to the main menu screen. It just stays at a black screen after the Respawn small text.
Out of options and really don't know what to do. I would take it to EA but i hate their customer service. But that will be the final option.
BF3 works perfectly btw.
UPDATE 16:30 02/07/2014: BF4 works perfectly after enabling page file. Had to create my own user.cfg from that reddit post. I think i'll just give EA help ago for titanfall. Thanks for the help guys.
https://linustechtips.com/topic/174410-bf4-and-titanfall-launchload-problems/
have you changed anything, updated/bought anything? did windows update?
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
EA customer service is your only option
(good luck lmfao)
damn
I haven't changed anything. Also i don't run windows update since i never saw the benefits but i could try that.
couple of screenshots on more problems.
http://gyazo.com/ff9168eaed7bcb0f550c9da057443679
^ RAM full errors. I don't run pagfile since it was taking up SSD space.
http://gyazo.com/173cfedc67d7d03fc06932fae7afbe05
http://gyazo.com/f248f1b1fbfaa20d1d92b07d3e73c9ed
^probably related to the RAM error. will re enable pagefile and see how it goes.
also from that reddit post my BF4 install didn't have a user.cfg file so i made one with those settings. worked for a bit until a i was killed and the errors showed shortly after that.
So what web browser are you using? People have problems with some web browsers crashing bf4.
I have no idea on titanfall.
CPU Ryzen 5 Asrock B350 Pro 4 / MSI RX580 Gaming / RAM 16 Gigs Corsair Vengeance 3000 / HDD 1TB Seagate Barracuda / SSD Samsung 840 120GB / 500GB Samsung SSD / Case Urban S31 / PSU EVGA G2 750w / Os Windows 10 / Keyboard Corsair K70 / Mouse Razer Naga 2013 (Won it from Linus!!
Chrome.
Titanfall is still a lost cause.
