On one of my recent builds not all the front USB 3 Headers where working 100%. One would work fine and the other would power my flash drive but wouldn't show it in "My Computer"
Project Casper - Glass Tubing Build
Ryzen 9 5905x     |    Gigabyte Aorus Extreme X570    |   Strix 3090
GSkill 64gb 4000mhz   |    EVGA 1600T psu     |      3x Samsung 980 Pro NVME 1tb Raid 0
  4 x Crucial MX500 2tb raid 0   |    Glass Hard Line Tubing  - EKWB Blocks
https://linustechtips.com/topic/174328-front-usb-3-not-working/
bump
https://linustechtips.com/topic/174328-front-usb-3-not-working/#findComment-2319445
try reseating the usb front header cable on the mobo
it could be the USB header cable
you could be able to find replacement cable for that
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/174328-front-usb-3-not-working/#findComment-2319494
