Ok so i have a somewhat old laptop but it is still working great but i have an integrated graphics card (Intel Hd 3000) old i know right, but it also has an Amd Radeon Hd 6470M, and i right click on my desktop and it shows that i am using the integrated graphics (Hd 3000) and idk how to change it. The laptop model is a Sony Vaio VPCSE1BFX. Thank you.
https://linustechtips.com/topic/174196-laptop-graphics-help/
see if this work for you
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/174196-laptop-graphics-help/#findComment-2313828
New to this forum, going to get a new laptop mainly for work but be able to play some games. and there's an option for which graphics card I want
NVIDIA® GeForce® 820M
-AMD Radeon HD 8670M
Note:The NVIDIA is $100 extra.....is it worth it?
why are you hijacking this tread?
the 820M is crap
the HD8670 will be better
https://linustechtips.com/topic/174196-laptop-graphics-help/#findComment-2313908
From those two: AMD Radeon™ HD 8670M
BUT, if you wanna game ocasionaly i would wait a bit and get Radeon 8750m or nvidia 850m
   i7 4770K 4.7 Ghz (1.285vCore, CORSAIR H110) - GIGABYTE G1 SNIPER M5 - MSI GTX 780 (Arctic Hybrid watercooled)- G.SKILL 16gb 2133Mhz cl9 - SAMSUNG 840 PRO 256gb - CORSAIR 350D - CORSAIR RM 750W
   LENOVO Y500 i7 3630qm 3.4 Ghz, GTX 650M SLI, 8gb 1600Mhz, WD 1tb, Cooler Master U2
     BUILD LOG: https://linustechtips.com/main/topic/26468-finished-350d-mini-gigabyte-killer-blackgreen/
https://linustechtips.com/topic/174196-laptop-graphics-help/#findComment-2313911
