   I was cleaning off my desk, getting everything ready to build my computer. I got my old case from the garage that was put in the box. (Corsair 350D) Got it out and cleaned it off. After doing that I realized there were no motherboard standoff's or any screws anywhere. I really want to use this case as I got a Mini atx motherboard to use instead of the one I'm getting in the mail. But is there a place online where I can order all the screws and such the case originally comes with? If not where can I run my computer without it burning it's self out, like in the motherboard box maybe?
https://linustechtips.com/topic/174147-issue/
http://www.newegg.com/Product/Product.aspx?Item=N82E16811998139&cm_re=motherboard_standoffs-_-11-998-139-_-Product
why would you ever remove the standoffs anyway...
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/174147-issue/#findComment-2313208
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/174147-issue/#findComment-2313214
I didn't think I removed them, there is one standoff in the case but the rest are gone i guess.
https://linustechtips.com/topic/174147-issue/#findComment-2313216
I think if you look carefully you will see that all but the one standoff is built in. The removable standoff is because some motherboards do not use that mount location.
https://linustechtips.com/topic/174147-issue/#findComment-2313251
What? There is one standoff I think is built in, and the rest need standoffs
See the 350D installation guide, http://www.corsair.com/~/media/Corsair/download-files/manuals/49_001149_revAA_350D_QSG_EFGISR_web.pdf. Only one standoff is included. There are dimples in the motherboard tray that act as standoffs for the other locations.
https://linustechtips.com/topic/174147-issue/#findComment-2313267
the 350D still needs standoffs.
PSU Tier List | CoC
https://linustechtips.com/topic/174147-issue/#findComment-2313278
No? When I got it all the standoffs were pre-installed, and it includes one extra standoff for a different size motherboard.
https://linustechtips.com/topic/174147-issue/#findComment-2313306
My mistake. If you are located near any size computer store you should be able to buy standoffs. They are also available from NCIX http://www.ncixus.com/search/?categoryid=0&q=motherboard+standoff, Newegg http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=motherboard+standoffs&N=-1&isNodeId=1, Amazon http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=motherboard%20standoffs&sprefix=motherboard+st%2Caps&rh=i%3Aaps%2Ck%3Amotherboard%20standoffs, etc.
Standoffs do come in different heights. I believe the usual size is 6-32, 6.4mm high.
https://linustechtips.com/topic/174147-issue/#findComment-2313390
