what size power supply?
Go to solution Solved by CwGoh,
Use this: http://www.service.asus.com/#!psu-calculator/c1ig3
But I would say go for 650W - 750W (Unless you're doing Titan Z/295x2)
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
https://linustechtips.com/topic/173046-what-size-power-supply/#findComment-2299207
lol 1050
What GPUs are you using lol. General guide is 700-ish
Personal Rig
https://linustechtips.com/topic/173046-what-size-power-supply/#findComment-2299251
