CPU cleaning
Go to solution Solved by flibberdipper,
I did it and it worked fine. Just make sure there is no residual crap left over and you don't have any fuzzies left over from the toilet paper.
In my experience, paper towel works a touch better (and there are less fuzzies).
so i really want to put my 212x on but i couldnt find any isopropyl alcohol at the chemist so is it ok just to use some toilet paper on its own? i also dont think i have a micro fibre cloth
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
https://linustechtips.com/topic/172886-cpu-cleaning/
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/172886-cpu-cleaning/#findComment-2297106
Thanks :) and ye i have plenty of time to get it right :)
|| MAELSTROM ||
https://linustechtips.com/topic/172886-cpu-cleaning/#findComment-2297108
