Hi all,
so after i playing some games for a bout 20 minutes my pc shut down and then looping on/off until i manually turn it off ,,,after a few minutes i can turn it on and is says that surge protector as occurred to prevent damage to the system ...has my psu almost gone is a Corsair ax860i not a cheap one ..any suggestion?  :huh:
https://linustechtips.com/topic/172634-power-surge-error/
Hi all,
I have encountered the Asus surge protection feature to glitch after a short power blackout (lasted like 20 sec) It kept telling me there was a problem and the system shut down to protect itself. I measured the voltage from the wall socket, and everything was fine.
I reseted the bios and the warning never appeared again, and the system didn't shut down again.
https://linustechtips.com/topic/172634-power-surge-error/#findComment-2294605
mmm i did reset the bios ...and now its seems fine but i just check the power outlet with a watt meter , and under load i get over 1000 watt so  thats not surprise to me that the psu cant handle that load for a long time ,,,,but if i remember correctly when i got the 2 780 i just got above 600 watt at stock when i gaming .....
https://linustechtips.com/topic/172634-power-surge-error/#findComment-2300530
