Need help for a friend
Go to solution Solved by dragoon20005,
Ooooh. That Athlon sounds tasty.
someone ordered an Athlon build?
here you go
the GPU can work with the PSU
the PSU has a PCI-E power plug
the 270 need only 1 plug
Motherboard: Asus A78M-A Micro ATX FM2+ Motherboard  ($59.78 @ Newegg)
Video Card: PowerColor Radeon R9 270 2GB TurboDuo Video Card  ($139.20 @ Newegg)
Case: Cooler Master N400 ATX Mid Tower Case  ($49.99 @ Newegg)
Total: $510.90
So I've been around here a while but I can never manage to get good budget builds.
My friend wants a gaming PC ~600$.
Right now all I have picked out is the CPU and Mobo size.
Mobo size: mATX
CPU: Pentium G3258
Primary use: Gaming
Budget: 600$
Buying From: Mem express
I don't think I forgot anything!
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
https://linustechtips.com/topic/172323-need-help-for-a-friend/
Motherboard: Gigabyte GA-Z97M-D3H Micro ATX LGA1150 Motherboard  ($119.95 @ Vuugo)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($79.99 @ Canada Computers)
Video Card: PowerColor Radeon R9 270 2GB TurboDuo Video Card  ($144.99 @ NCIX)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($47.95 @ Vuugo)
Total: $610.46
closest i can get
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/172323-need-help-for-a-friend/#findComment-2290285
Will he be upgrading his CPU in the future?
No. I will be OCing it thought
Total: $610.46
closest i can get
I'll get something! Probs something like this. I can pick up an EVGA 430W for ~35$.
https://linustechtips.com/topic/172323-need-help-for-a-friend/#findComment-2292676
Well, it doesn't make much sense... the new Pentium is rather for enthusiasts who don't need the power. It's better to get AMD in this price. Also 2 cores are very limiting.
I see, do you think the FX 4300 would be a good choice? or one of the other new low end CPUs?
https://linustechtips.com/topic/172323-need-help-for-a-friend/#findComment-2294976
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  ($144.99 @ Memory Express)
Motherboard: MSI CSM-H81M-P32 Micro ATX LGA1150 Motherboard  ($69.99 @ Memory Express)
Memory: Kingston Blu 8GB (2 x 4GB) DDR3-1600 Memory  ($84.99 @ Memory Express)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($119.99 @ Memory Express)
Video Card: EVGA GeForce GTX 750 1GB Superclocked Video Card  ($139.99 @ Memory Express)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($59.99 @ Memory Express)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply
Total: $619.94
https://linustechtips.com/topic/172323-need-help-for-a-friend/#findComment-2295043
Is a copy of Windows or any peripherals needed?
https://linustechtips.com/topic/172323-need-help-for-a-friend/#findComment-2310921
  • 2 weeks later...
 what I would recommend is that 80 dollar Athlon maybe, the quad core one.  Or bump it to the i3 but a cheaper mobo since no overclocking is to be had for that card.
https://linustechtips.com/topic/172323-need-help-for-a-friend/#findComment-2408620
here you go
Total: $510.90
https://linustechtips.com/topic/172323-need-help-for-a-friend/#findComment-2410188
