Hi guys,
I've got a rather curious question about GPU memory clock speeds.
Here it is:
• How come when a GPU memory's clock speed is shown in MHz and they do "x4", why is it then shown in brackets as Gbps?
I'll give you an example.
Take NVIDIA's GPU the GTX 770. It's memory clock speed would be shown as 1750MHz x4 and then in brackets (7Gbps). Shouldn't it be shown as (7GHz)?
I hope that's easy enough to understand. :unsure:
Thanks in advance for your help. :D
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/172321-gpu-memory-clock-speed-question/
I'm more specifically referring to the fact that they put the full clock speed in brackets as "Gbps" instead of "GHz". You wouldn't say that 4,000KG equals 1GHz would you? It just doesn't sound right.
its a misprint, 1750mhz(gddr5)=7ghz or 7000mhz "effective"
the only time you can get a transfer speed is when you talk bandwidth i.e r9-290 with 1250mhz(x4)is 5ghz effective and with a 512 bit wide bus that means it can transfer data into the frame buffer (vram) at 320GB/second
fyi its not the same as ram speeds.
ddr3 1333 ram is also named/called 10600 (you wont really hear it called that verbally obviously) this is because it can transfer 10.6GB/s of data, double that if run in dual channel.
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
That's what I thought. But I think NVIDIA and AMD have put "Gbps" instead of "GHz" under the specifications of each of their GPUs.
I think they're a little confused to be honest. :huh:
Yep, this what I thought also. They really need to fix it.
GDDR5 is x4
DDR3 (or GDDR3) is x2
so, if you have 1250 mhz of DDR3 = 2500 mhz of eVram speed
and if you have 1250 mhz of GDDR5 = 5000 mhz of eVram speed
(is not perfect, but help to see the point)  :rolleyes:
DDR is x1  :blush:
APU = A10
GDDR5 is x4
DDR is x1  :blush:
Thanks for that! :D
