diferrent rams... will they work?
Go to solution Solved by dragoon20005,
they will work
but the new RAM will clock to 1333MHz to match the old Kingston RAM
you will be better off the new 8GB and use the old RAM on another PC
hi there guys so i have a simple question i have some old rams on my pc "blue hyperX kingston 1333 cas9" 2 stick with 2gb's each, i was thinking in buying  some kingston fury 1866 cas10 2 sticks of 4gb each
can i use the 2 old ones with the 2 new ones so i can get 12gb of ram???
https://linustechtips.com/topic/172260-diferrent-rams-will-they-work/
they will work
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
