Hi guys,
i have this problem, when i start my old pc, this is what happens..
https://www.youtube.com/watch?v=TbFZ-h0zA2c&feature=youtube_gdata_player
thanks for your responses
Whatever the issue it, the gpu is dead, its past the 5 year period, its around 6 years old now or problems are likely to occur. As for this i think one of the capacitors has lost its edge, check the pcb of the videocard, if the caps are swelling or burst its a goner, dont fall into the trap of trying to solder new caps on the gpu, the most likely outcome is that whatever broke them in the first place will break them again. Just get a new gpu you dont really have a choice, gt 510s or a radeon 5450 are pretty cheap these days.
Listen if you care.
https://linustechtips.com/topic/172152-asus-9400gt-gpu-problem/#findComment-2288127
your GPU is dead, as other have said.
However, they told you to buy graphics cards that are very hard to find these days.
Get an R7 260X and if you have at least a core two duo, there will be no bottleneck.
They are about $140 online, and they are well worth it.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/172152-asus-9400gt-gpu-problem/#findComment-2289158
If the caps look fine you can always bake it in your oven. (No joke, i am dead serious.)
its dead. either way, the gpu itself is not worth the energy bill raise caused by the oven.
https://linustechtips.com/topic/172152-asus-9400gt-gpu-problem/#findComment-2292306
