CPU upgrade or not?
Go to solution Solved by Createinator,
Get an i5 with Z87/97 motherboard ~ you will see considerable performance upgrade from your 920.
Hey guys it's me once again. I'm starting this topic because I need for the third time your help. I used to have an i7 920 (2.66 Ghz) with a gtx 560 Ti and 12 Gb of RAM, powered by a 600W PSU from PowerX. Yesterday my motherboard died on me and there was no way to fix it. I wondered what I should do. Should I just buy a motherboard compatible with my CPU or should I buy a new motherboard and upgrade my CPU.
What I had in mind was a CPU that was good for gaming and also for emulation.
My budget is 400 euros.
What should I do?
I await your responses...
https://linustechtips.com/topic/172027-cpu-upgrade-or-not/
What @Createinator said.  An i5-4690k will blow you away.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/172027-cpu-upgrade-or-not/#findComment-2285085
Yes! full on i5k with z97 board!
 i5 3570k @4.all over the place || CM Hyper TX3 Evo || ASRock Z77 professional-m || 8GB G.SKILL Ripjaws Z 2400mhz CL10 || MSI GTX770 2GB OC'd 1280/3825mhz || ADATA SP900 128GB || Fractal Design Arc Mini R2 || Logitech G502 || Audio Technica ATH-M50
A spy is always better than a ninja!See burn notice. EVERYTHING is just a number!
https://linustechtips.com/topic/172027-cpu-upgrade-or-not/#findComment-2285088
See above answers. i5k with z97
CPU: Intel I7 4790K 4.8 Ghz || Mobo: ASUS ROG Maximus Hero 6 Z87 || Ram: Corsair Vengeance 16 GB 1600 Mhz || GPU: ASUS GTX 980 Ti STRIX || Storage: 2 x SSD Samsung 840 EVO 250 GB RAID 0 HDD Western Digital 1 TB Black || PSU: Corsair AX 860 watt || Cooling: 2 x AF 140mm (front), 2 AF120 Blue LED (bottom and back), 2 SP120 (top on radiator) ||  CPU cooler: Corsair H100i GTX || Case: Corsair obsidian 750D <3 <3 <3
https://linustechtips.com/topic/172027-cpu-upgrade-or-not/#findComment-2285092
Thanks for the replies guys but I have a problem. The z97 motherboards don't appear to support 1066 mhz RAM (the one that I have). Any suggestions?
If they are DDR3 1066mhz they should work, if not toss em away and get a new 8GB kit of DDR3 1600 or 1866MHZ the cheapest you find and call it a day those can be found around 60$ to 70$ nowadays..
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/172027-cpu-upgrade-or-not/#findComment-2285298
Yes i_build_nanosuits they're DDR3. I should be safe then...
i think it should, only way to find out for sure is to try it out but i'm confident it should work...if not then you'll have to upgrade them.
https://linustechtips.com/topic/172027-cpu-upgrade-or-not/#findComment-2285548
Ok guys I did some research and I found these two components:
Motherboard:
http://www.e-key.it/prod-scheda-madre-msi-z97-gaming-5-intel-z97-socket-1150-ddr3-sata3-usb3-atx-53100.htm
CPU:
http://www.e-key.it/prod-cpu-intel-core-i5-4690k-socket-1150-35ghz-6mb-intel-hd-graphics-hd4600-88w-boxed-53713.htm
The site is in italian but the specifications are in english so you should understand them.
What do you think of them? Are they fine?
https://linustechtips.com/topic/172027-cpu-upgrade-or-not/#findComment-2287226
Motherboard:
CPU:
Yes that is absolutely perfect, this will be used strictly for gaming right?
https://linustechtips.com/topic/172027-cpu-upgrade-or-not/#findComment-2287420
that's perfect, plan an aftermarket CPU cooler in your build if you plan to overclock the CPU, this is a great kit it will perform very well and even allow you to run dual GPU setups in the future if you want to.
https://linustechtips.com/topic/172027-cpu-upgrade-or-not/#findComment-2287484
Thanks i_build_nanosuits, you've been extremely helpful ;)
you're welcome. Are you planning to upgrade your GPU as well cause the 560ti is pretty weak by today's standard...you have a lot of worthy upgrade cards that won't necesseraly break the bank out there..cause the CPU only plays a second role in gaming, the primary part for performance being the GPU and you want to keep a good balance between both of them, now you will have a blazing fast CPU that would be pretty much useless because your GPU isnt powerful enough to take advantage of it..
https://linustechtips.com/topic/172027-cpu-upgrade-or-not/#findComment-2287516
they are not coming out before some time yet from what infos i've been able to gather some sources say it's unlikely to come out before Q1 or Q2 of 2015...that can still be a long wait...also most states that it will probably be a good improvement in terms of energy efficiency and heat output but probably not that big of a leap in terms of performance...but that we can't tell for sure. One thing i can tell you tho is that AMD GPU's are currently very agressively priced and you do get a lot of bang for your bucks...something like an R9 290 wich performs about the same as a GTX 780 and max out any games out there can be purchased at a very reasonable price...if it's still too steep you could even look at an R9 280X...nvidia cards cost more for the same performance. But its all up to you i'm just telling you what i know about this.
If you're still okay with the performance of your current GPU i guess waiting to see how the next gen card do can be possible :)
https://linustechtips.com/topic/172027-cpu-upgrade-or-not/#findComment-2287672
