He should build a totally new system, everything there is way out of date, it wouldn't be worth it to spend more money on it.
Also, 200W PSU??? lolwut
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/171955-need-help/#findComment-2283987
He must change PSU first, for not to destroy his PC. 200W PSU is so weak, that he should not stress his PC at all.
New PSU + GTX 750Ti or R7 265.
Intel i7 2600 @ 4.2 Ghz | MSI Z77-GD55 | Crucial 16 GB DDR3 RAM 1600Mhz | Intel 330 SSD 180Gb | Western Digital Black 1Tb | Western Digital Green 2Tb | Gigabyte GTX 650 Ti | OCZ ModXStream Pro 500W | Thermaltake Commander MS-I case | OS X Yosemite | Dell Vostro 3550 Windows 10
Intel Xeon 1230 V2 | Gigabyte GA-H61M-S | Kingston 4Gb RAM 1333Mhz | Seagate 1TB  | Fractial Design Arc mini | Windows 10
https://linustechtips.com/topic/171955-need-help/#findComment-2284011
With a 200watt psu you can't buy a graphics card that I would consider decent and low end gpus aren't worth the money anyway. If you want to change it, I suggest you get at least a 400watt psu and a radeon hd 7770 Ghz, you can find those for dirt cheap nowadays. You should consider a completely new system soon either way.
sudo chmod -R 000 /*
https://linustechtips.com/topic/171955-need-help/#findComment-2284032
