Thermaltake psu
Go to solution Solved by H4X3R,
Depends on the model, like ALL other PSU manufacturers / sellers.
why should i get corsair or cooler master or  seasonic?
You don't have to.
In fact most corsair PSUs are overpriced and suck in terms of build quality.
Here is an article to the much supported RM series (wayyy too overpriced IMO):
http://www.overclock.net/t/1455892/why-you-might-not-want-to-buy-a-corsair-rm-psu
If you are a corsair fanboy, ONLY buy the HX/i or AX/i series.
Here is a good quote to sum up Corsair
Corsair PSU's have never been very good from the hardware to software. I'm surprised people still buy them. Always so many problems.
There are very many issues with corsair link (a corsair link user myself). It messed with my mobo and cpu sensors, reporting wrong voltages and temperatures.
Seasonic is referred to as the best in terms of build quality (and is among the best), therefore the high price. There are other great ones, like superflower and channel well.
Most cooler master PSU actually sucked, just recently they started making good ones like the v series. Any other cooler master PSU is bad / junk.
If you need any further assistance, feel free to post a new thread in the Case and Power-supplies section of this forum.
i am currently using a thermaltake psu its been pretty reliable for last 2.5 years but i would stil say get something like seasonic or corsair if you can.
https://linustechtips.com/topic/171919-thermaltake-psu/#findComment-2283615
You don't have to.
Samung Tab S 8.4
https://linustechtips.com/topic/171919-thermaltake-psu/#findComment-2283710
