It really is fine.
Post your full specs just for a second look.
 i5 3570k @4.all over the place || CM Hyper TX3 Evo || ASRock Z77 professional-m || 8GB G.SKILL Ripjaws Z 2400mhz CL10 || MSI GTX770 2GB OC'd 1280/3825mhz || ADATA SP900 128GB || Fractal Design Arc Mini R2 || Logitech G502 || Audio Technica ATH-M50
A spy is always better than a ninja!See burn notice. EVERYTHING is just a number!
https://linustechtips.com/topic/170800-upgrade-psu/#findComment-2269594
It's fine, that's just a raw estimate. It wont be running full 694W all the time. you're fine.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/170800-upgrade-psu/#findComment-2269599
Just to clarify these parts are all bought and the system is put together and running.
http://pcpartpicker.com/p/bLxK23
Noice!
The psu will be fine but you don't have to much headroom for a cpu overclock.They tend to suck a lot more power once you overclock them.
https://linustechtips.com/topic/170800-upgrade-psu/#findComment-2269636
So bumping it up to 4.5 would not be advisable?
Use the quote button in order to get notified ;)
Um,nope,i wouldn't do it.If i had that build though,i would buy a better psu from the start.Something like this http://pcpartpicker.com/part/evga-power-supply-220g20850xr
https://linustechtips.com/topic/170800-upgrade-psu/#findComment-2269701
