Hi guys, I just managed to build my first computer!  Everything went well and I'm pleased with the result.  There is one problem, however.
The hard drive seems to be inaccessible.  By this I mean that it shows up as recognized in the bios and device manager as fine but when I open up the computer directory, It doesn't show up.  It is a Western Digital Caviar Blue 1TB HDD.  Luckily, I can still use this computer since the OS is installed on an SSD.  The SSD is fine but the HDD is nowhere to be found.  Do you suppose the drive is just DOA?
Thanks in advance.
Edit:  Here is a screenshot that may help
i5 4670k (can OC to 4.4Ghz) - Hyper 212 evo w/ AC MX2 - XFX Radeon R9 280X8GB ADATA XPG V2 DDR3-1600 - MSI Z87 G41 - Corsair CX600M 600W PSU - 1TB HDD - 120GB SSD
https://linustechtips.com/topic/170784-hard-drive-not-working/
How big is the HDD?
My Stuff! :D
My Stuff
  • Main Build - Soon to change due to it being dead
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 16GB Corsair Vengance  Blue LP 1600Mhz
  • 120GB Samsung 840
  • 2TB Seagate Barracuda
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • Bitfenix, Corsair, and Darkside cable extensions
  • Das Professional with Cherry MX Brown's & Custom Keycaps
  • 3x ASUS VS238H-P w/ Triple monitor mount in PLP
  • AudioTechnica ATH-M50's
  • Blue Yeti Microphone
  • TurtleBeach PX3 Wireless
  • Logitech C920 Webcam
  • Precision Audio Bookshelf Speakers
  • AudioSource AMP-100
  • Logitech G27 Racing setup
  • Laptop - Acer 7750G-9855
  • i7 2630QM
  • AMD 6650M GPU
  • 120GB Samsung 840 EVO
  • 8GB RAM
  • Operating System: Windows 7 Home Premium
  • Blu-ray Drive
  • Netbook - HP Pavillion DM1
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • Cell Phone - OnePlus One
  • 5.5-inch 1080p Screen
  • Qualcomm Snapdragon 801 processor @2.5Ghz
  • 13 Megapixel rear camera
  • 5 megapixel wide angle front facing camera
  • 3100 mAh non-removal battery
  • AC wifi
  • Cell Phone #2 - Nexus 5
  • 5 Inch 1080p Screen
  • Snapdragon 800
  • 8 megapixel rear camera
  • 1.3 megapixel front camera
  • 2300 mAh non-removable battery
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
  • 1x 1440 or 1600p Monitor
  • Das Mechanical Keyboard
https://linustechtips.com/topic/170784-hard-drive-not-working/#findComment-2269418
1 Terabyte
You may have a bad HDD, I honestly do not have much expertise with things of this nature but I would suggest trying the HDD in a different system around your house if you can.
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/170784-hard-drive-not-working/#findComment-2269561
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/170784-hard-drive-not-working/#findComment-2269619
I got to disk management and found the HDD.  It is unallocated.  Does that mean I need to format it?  How do I do that?
https://linustechtips.com/topic/170784-hard-drive-not-working/#findComment-2269714
yes follow the steps to format it and assign the drive letter
https://linustechtips.com/topic/170784-hard-drive-not-working/#findComment-2269721
