My current setup is:
1x 120mm front intake flow
1x 120mm exhaust
1x hyper 212 cpu cooler with 120mm mounted static pressure
1x 120mm side panel intake flow
My graphics cards have a hard time being cooled and i was wondering if I should be using a static pressure side panel fan or flow intake/exhaust.
Please let me know thank you.
https://linustechtips.com/topic/170754-need-help-with-side-panel-fan/
1x 120mm exhaust
No side panel fans do nothing what so ever for temperatures, if anything they disrupt the airflow in the case.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
don't get side panel fans...worst invention by case manufaturers ever!
I disagree with you guys. Or partly. Most times sidepanel fans are small 120mm or in wrong place. Bigger fans in right places will provide help in cooling and don't distrupt airflow.
So OP, best thing would be if you could add more intake to front. The sidepanel fan is good to use as intake if its over GPU or bit lower than it. If its over your CPU, then it does nothing to GPU. What case/fans you have?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
It would help to list your specs.
I'm confused?
Side panel fans are a bad thing?
They can be at times. Depends on the scenario.
