How to mount reservoir to pump directly
Solved by Shaqo_Wyn,
Hi Shaqo, thanks for the reply!! so I must buy this on top of everything else that I bought so far from above?
This would work with the D5 mod kit and d5 top I purchased right?
Yes. It's a shame that you already bought a separate res. The upgrade kit comes with the D5Top adapter, o-rings, screws etc. and a res so that it can be mounted to your pump top. Maybe you can return the other one? You could also keep it for the multi fill port top, cuz the upgrade kit res top only has a single hole.
Welcome to LTT. Follow your posts to be notified when you get new replies and quote comments you reply to so that the person that replied gets notified.
https://www.frozencpu.com/images/products/pdf/ex-res-365.pdf
