I was really reluctant to make a Rockstar account but seen as you are forced to make one I gave in and made one but the only problem is I can't  link my account to my steam account and when it does work it asks me again every time I log back into the game. Also when Rockstar shuts down the servers for Max Payne 3 what will happen to the game. Will it still be playable because at the moment it isn't as if the servers went down you would be screwed.
 (\__/)
(")_(")  GTX 1070 5820K 500GB Samsung EVO SSD 1TB WD Green 16GB of RAM Corsair 540 Air Black EVGA Supernova 750W Gold  Logitech G502 Fiio E10 Wharfedale Diamond 220 Yamaha A-S501 Lian Li Fan Controller NHD-15 KBTalking Keyboard
https://linustechtips.com/topic/170466-max-payne-3-problems/
Just download the crack for the game, problem solved. If you can find the crack only you wont have to worry about getting in trouble and you bypass that always on bs. This doesn't take any multiplayer into account, but it would allow you to play the game with the servers down (minus multiplayer[however some cracks allow multiplayer to still work but its a hassle]). Otherwise when servers go down that are hosted by devs and the game relies on them, then you can;t play the game anymore. Think of the games you have to be online to play as a rental because one day you won't be able to play them anymore just because servers are gone... unless you download the cracks for the games. ;)
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/170466-max-payne-3-problems/#findComment-2265536
